Walbro install gone wrong
psychlow
2,864
15
Jun 30, 2003
Colorado Springs, Colorado
Okay - I've had about the worst month trying to get this Walbro fuel pump into my car. I say month, because, well, it took two weeks to get the pump out of the car. From there, I had to cut the nozzle that's welded to the pump assembly because there wasn't enough line to flare.
From there, when I was installing the positive cable to the underside of the pump, <click!> the stud breaks. Shit.
So, here I am with a screwed up pump assembly, which I'm going to have to drill through to get this thing to work again.
Here's what I'm worried about, now.
I know I need to use heatshrink tubing and all, but I noticed that in stock form, the terminals for the power cords run in protected boots where it's not possible to cause a spark. However, when installing the Walbro, you have to remove the boots (which I will reuse) but they don't look like they're going to seal as well as they used to.
So, if fuel happens to contact both power terminals (+ and -) completing the circuit and causing a short, what keeps it from ripping me and the car to shreds when and if it sparks?
Am I just being retarded? I think this is something to really consider when jacking with fuel pump wiring!
vist www.vfaq.com ... click where it says DSM modification site here
.. then click on fuel... then click on the install that best fits your application. (eg. 1G/2G..FWD/AWD) walbro install.
you will love it :thumb:
