Walbro 255 Fuel Pump 95-99 Eclipse/Talon
Turbizmo
430
Jul 3, 2005
Salinas, California
I have a question. Yesterday I was installing the walbro fuel pump to my 97 420a. As I was installing it everything was coming out right. I drilled another whole like some people do to mount the fuel pump right but then i saw something that caught my attention. I saw that the aftermarker fuel pump had two other wholes close to where it conects one said + and the other one - and i dont know if any wires go there. I am afraid to turn on my car because I dont want anything to happen. :rolleyes:
oh thats another way to connect the power, as long as you plugged in your harness you should be fine,
if you turn the ignition on without turning on the car you will be able to hear the fuel pump prime, if you can hear it you're good to go
the install is very simple there really isn't much you can screw up
The harness is plugged up already. So it will be fine if i dont do anything to does two + and -?
