newdsmtnr96
- 250
- 1
- Apr 16, 2005
Des Moines,
Iowa
This morning I started my car... waited about 10 min for it to warm up, I been hearing a clicking noise.. I'm not totally sure where it is coming from. I know its coming from the back of the engine. Like the intake manifold. But I know that its not a gasket or anything because when I put my motor back together me and my motor guy Replaced all the gaskets and everything. Everything has been replaced. Now heres my issue, I think that a auto store sold me some bad injectors or something. Its totally coming from the intake area. Is this ticking normal? Oh yah a little more info on my motor. everything from top to bottom has been replaced, Lifters, valves... except cams and coil pack. Im asking a lot of questions cause Im not sure what it is. My motor now has 1700 miles on it. Car runs good idle is a little off. like 800-900 not sure if that is normal either.. But maybe Im just Paranoid. Im not sure what could be causing the clicking. Could injectors click? I want to replace them with bigger ones or Rc injectors.. any one have any suggestions or anything? My current set up is.
Wesco low compression pistons
Eagle rods
Chrome molly crank
Stainless steel ferrea valves
Crane valve springs
Stock cams
Ported and polished head
Low compression head gasket
Arp head studs
I dont think that it should be ticking, any one has any idea i would appreciate any idea's
thanks
Lance
Eagle rods
Chrome molly crank
Crane valve springs
Stock cams
Arp head studs
thanks
Lance
but um you think it could be bad injectors? they usualy make a click? i wanna replace them... I've got a fmu and turbo kit to be running 6 pounds.. what size should i go with if i figure it is bad injctors?
