This guide is for the OEM door handles and door checks with related parts for the North American 2nd generation Mitsubishi Eclipse and Eagle Talon.
Disclaimer: this info may not be comprehensive or exhaustive, and may contain mistakes or errors. If you see a mistake or something missing, feel free to drop a comment. :)
Exterior Door Handles
Handle Assembly
OEM assembly includes a handle, clip, and door lock cylinder ring.
Note: part numbers below are for black, which supersedes all other colors.
  • Left: MB913151
  • Right: MB913152
Replaceable Components
  • A) Clip (1 qty. per handle): MU481093
  • B) Ring (1 qty. per handle): MB676441
Fasteners
These fasteners are NOT included in the OEM Door Handle Assemblies.
  • M6x10 Washer Assembled Bolt (2 qty. per handle): MU240087
Door Checks
These prevent the doors from opening too far, and help hold it in the open position. Left side shown.
  • C) Door Check
  • D) Spring Pin
  • E) M6 Washer Assembled Nuts
C) Door Check
Left OR Right: MR137843
Fasteners
These are NOT included with the OEM Door Check.
  • D) Spring Pin (1 qty. per door check): MB632510
  • E) M6 Washer Assembled Nut (2 qty. per door check): MS440502
