vibration like tires unbalanced... just disappeared?
Korndogg
471
Jun 21, 2003
randolph, Vermont
hey all..
i have a question.. which is probably a stupid one.. but here it goes anyway :p
i bought my car probably about 6-8 weeks ago, and it's always started vibrating very noticeably at 105-110.. like the front end bouncing up and down a bit.. so i figured, oh great.. the winter tires (which are on the front but not the back) weren't balanced as well as they could be..
but today i took a trip to sears (20-25 mins away at 90-100mph.. heh).. on the way back, i suddenly realized that there was no vibration at all at high speeds.. i went up to 120mph several times and got no vibration..
now.. my front right ..something.. makes a noise whenever the clutch is engaged and i'm either accellerating or decellerating.. so i think it's my CV joint.. it's kind of a light metal/metal rubbing noise
i was also told after getting my car inspected that my driver's side inner tie rod needs to be replaced.. and it's bad enough so that i can feel that the car will turn more responcively to the left if i snap the wheel, then if i snap the wheel to the right.
my question is this(obviously)... why did the vibration go away? it's apparently not caused by tires being unbalanced.. or it wouldn't go away.. so what do you think was causing it? the CV joint? the tie rod? i don't yet know if the vibration just happened to go away, or if it was due to something heating up after driving so fast for half an hour...
also, is this dangerous at all?
thanks a LOT!
Hmmmm, you have a bad tie rod, all that does is control your steering. Whats the worse that could happen if you're running 120 and the wheel snaps to the side on you.
Of course its dangerous, especially at the speeds you like to travel.
heh, yeah.. i was waiting for that answer...
that's not what i meant though.. and that's not generally how i travel to sears.. annywwayyyy.... anyone know why the vibration would just go away? and is it more likely to be the tie rod or the other noise (i think it's the CV..)
thanks again
Some may find the stated facts to be so.
Lessee.... you're driving a car you've had for two month with snow tires on one end at speeds around the century mark. I don't see any point in being concerned about it. It shouldn't be an issue for a full six months anyway.
You have any decent parts we may be wanting to contact your surviving kin about? Please make pre-arrangements.
And no Looky-How-Stupid-I-Am forum to move this to, either. What rotten luck.
