Vibration in front end when I am on the gas??
triton185
May 27, 2005
Kernersville, North Carolina
I have a 95 talon tsi have strong vibration in the front end when i am on the gas. As soon as I let off it completely goes away.
It is worse going up hills. Could it be a bad axle or clutch related?
The clutch is not slipping from a start or during shifting.
thanks in advance for the help :talon:
The problem could be a ripped CV boot, axle, or your balance shaft might be off some degrees causing your motor to shake. if you have done some extensive engine work i.e. head gasket swap, t-belt swap, something that involes messing with your timing could of caused it.
Dont jump to conclusions, could be something more simple than a clutch or cv boot. Could just be a misfire. Check small things first.
