Valve Cover leak?
majik2k5
799
18
Jul 13, 2005
Lemoore, California
I have an oil leak after I took my valve cover off and put it back on. I replaced the gasket and siliconed it on with some gasket maker, and it still seems to leak. However, it looks almost like it's spraying somewhere. And there is oil in the spark plug section of the valve cover, so I don't think it's possible for it to leak upwards.... :confused:
Any help would be good. :rocks:
It could be leaking around the circle gaskets that go around the spark plugs on the valve cover. Is there oil on the valve cover? Pull the plug wires and see if theres oil on the upper thick part of the plug wire.
