valve cover cracks
Don't "torque" them at all. Just snug them down. Be especially wary of the inner ones, where the loads through the casting have a pretty horrible distribution path.
Torqueing valve cover screws will crack the cover. Perhaps you needed to see that in writing, since doing it over and over didn't seem to illustrate the situation too well.
actually the tq spec is 10 INCH lbs which is less then if u tighened them with an extension an 10 mm only no ratchet less then snuggif that makes sense haha and i do install them frm inner to outter.
on the most recent one i didnt like i said i used a 1/4 in extention and a 10mm ONLY no ratchet i did it by hand and im no bodybuilder haha.
