upgraded calipers
lilbro717
207
Jan 28, 2008
San Dimas, California
im planning on doing one of the oem big brake kits with 13" rotors, was wondering which calipers are better, dont care about the size of the rotors, the 1g 3kgt vr4s, the 2g 3kgt vr4s, or the cobra calipers? thanks
From what I have found the 1g and 2g 3000gt vr4 front calipers are the same. Fronts will require a bracket to bolt up.
The 1g 3k gt rear is styled more like our normal rear brake. Almost the same other than it has the nice mitsibushi lettering.
The 2g 3k gt vr4 rear caliper is a twin piston. Both are a direct bolt on. You can't use the vr4 rotor though because of the ebrake setup.
The cobra calipers I have no idea about the rears.
  • Wanted 6 bolt NT water pipe
    • chrisman287
