Universal PTU / Power Transistor Unit Brackets
Boosted Fabrication
Supporting Vendor
12
90
May 29, 2018
Charleroi, Pennsylvania
This is a must have for running an Evo 3 intake manifold or any other aftermarket manifold, it's even a must have running a simple 6 bolt swap in a 2G!
Made of aluminum, integrated threads, stainless steel hardware for mounting the PTU included. You will need to supply your own hardware for mounting the actual bracket.
Also the Evo 3 coil pack bracket can be found here.
May I suggest you not cut all the way through the aluminum for your logo so crud won't collect between it and the PTU. I also use white heatsink grease between the PTU and the mounting surface to aid in the heat transfer and life of the PTU. Not cutting through would provide more surface area in contact with the PTU.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
