UnGodly Overboost
JayB12
544
Jan 12, 2009
Philipsburg, Pennsylvania
So I was just driving around today after tightening my new serpentine belt, then I sprayed my car off. I got into boost real quick and let off. The bov sounded completely different, so I did it again and noticed I had spiked to 27psi! I normally only run 14. So it's Doubled! I don't know how this is even possible?
You can use an air compressor to pressurize it, or pull on the rod to see if it moves at all.
Make sure your boost source line didn't come loose to your wastegate. It happened to me and it cost me a head gasket.
Okay, I ran to autozone and picked up a vac hose to check the wastegate. So what I need to do is connect this to the nipple on the acctuator and pressurize it to ~12psi to check if the wastegate opens. Correct?
On another note, my car has been sluggish the past 2 weeks when I hit boost it doesnt feel like anything anymore, but my gauge reads 14psi. I thought i as a boost leak so I ordered a boost leak tester from ebay and it has yet to come. Do you think that was a sign that my acctuator/wastegate was going to fail?
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Okay. Just tested the wastegate, it opens fine. Could it have been the vac hose that goes to the MBC that was loose or something?
It must have been this hose. It's okay now.
Yep sounds like your hose came loose or maybe had a crack in it.
Good to here you got it fixed that could have been a big problem if left unattended.
