Underhood Switched Ign 12v source?
unclesam099
151
Aug 4, 2004
SE PA, Pennsylvania
Where under the hood can I find a 12v switched ignition source? I'm not savvy when it comes to wiring, so I'm sure it's pretty obvious and I just don't know it.
It's for a relay. Thanks!
For a water injection setup. The relay will be mounted on the firewall, so that wire would probably be fine.
Someone's page uses the fog light fuse in the box. Could I use that fuse? I don't have fog lights on my car, so it wouldn't screw anything up... Right?
Upper right corner of the harness going to the wiper motor for another. Mark
I've been looking at the wiring diagrams. While the headlights (and foglights) themselves are hot all the time, the relay that controls them are switched.
You can also try the relays that control the radiator fans as well.
Another thing you can try, if your fuel pump is rewired, is to tap the power from the relay that was installed during the rewire. That relay is controlled by the MPI relay.
