Two Crankwalked Engines. What Next?
MattyD
37
Jun 13, 2003
Lansing, Michigan
As the title says, I'm on my second crankwalked engine. What really gets me is that I just replaced the engine 6 months ago. (It was a used engine) Anyway, I am a little unsure as to what I should do now. I don't really have the option to sell the car, and I don't really have a lot of money to fix it. I would like to fix it correctly for the lowest amount of money. I would also like to get a little more performance out of it (even if it costs a little extra).
Some of my ideas are:
1) New short block. (Not too exciting, no more performance, cheapest)
2) New 6 bolt short block (Also not exciting, no more performance, cheap, safer than 7)
3) Replace crank, bearings, rods, pistons with 7 bolt 2.4 stroker kit from slowboy
4) 6 bolt stroker short block
5) 6 bolt 2.4 with stage IV head (Only if I win the lotto :) )
The one I was really looking at was 4. The thing is I'm sure that there would be machine work to be done (not sure what) And I really have no idea about building engines. (deepest I have gone into engines was removing the balance shafts from the current one)
If you think that the 7 bolt 2.4 would be a good idea, please provide any info you can on what would be involved to do this. Otherwise let me know what you think would be a good idea.
~Matt
(Also, do you think I could possibly take any legal action with 2 crankwalked engines and many other documented cases?)
it's funny, If i owned a 7 bolt motor and it walked i would never drop in another 7 bolt or rebuild one because crankwalk will always be on the back of my mind :nono:
imo just get a 6 bolt and rebuild the sucker with 2g pistons which can handle more than most people will ever need and have fun
My condolences, that sucks. Well alot of us have been in the money pit too, if it makes you feel any better.
Here's what I think you should consider:
Buy a used 6 bolt engine, either short block or long block. Do a basic rebuild if it seems like it needs it (depends on wether you buy a cheap engine that is mostly a core, or get a better condition engine which would cost more but need less done to it).
No more 7 bolts for you! Absolutely no more 7 bolts!
Do a search here for an engine, you will get at least 50-100 matches nationwide. Prices as low as $300 for a short block, on up to $2000 for a rebuilt engine with a warranty, and everything in between.
www.car-part.com
I'd probably just try to get it in good stock form, drive it a while, then look at upgrading it (the stroker option, as an example) later on. Unless you are really not in a hurry to get it running, then I say buy the 6 bolt short block and build it to your hearts' content.
I like the way you stick with it, you don't give in easily. Not like some ####ies that sell their DSM's.
I would just grab a 6 bolt bottom end, and rebuild the bottom end with 2G pistons, get all new bearings and gaskets, you should be fine. I wouldn't really do a stroker with your setup though.
I'm curious as to why you say don't get a stroker. Doesn't everyone want more torque? I would eventually like to road race this car. I would think that The 2.3 would help out.
~Matt
Ok, I can completey relate. I crankwalked more than a month ago, and was busy trying to get quotes for a 7-bolt rebuild. Every single shop, inlcluding RRE and SBR, said that getting another 7-bolt was a waste of dough, and I should spend a little more on a complete swap. After much thought, i figured it really wasnt worth crankwalking again by saving some money now. So I ordered a stage II 6-bolt long block from SBR. Go with a 6-bolt man, the 7-bolt will only bother you in the future... it blew a hole in my bank account, but thats what being a DSMer is all about. LOL. :p
So I am definitely going with a 6 bolt. I'm still having trouble deciding on the 2.3 stroker or to stick with the 2.0. I am FWD so I wonder if I will have problems with traction. I'm sure having the Evo III 16g will just make it worse as well. This is not going to be a drag car, If it ever makes it to a track it will be a road course. Thanks for all the input on this.
~Matt
With FWD, I suppose LESS TORQUE would be better then? I hear you say you are worried about wheel spin. Then stick with the 2.0, and keep stock 1G lower compression pistons!
Besides it's cheaper and easier that way.
Gives you a less costly alternative to get up and running quicker and easier.
  • Wanted 6 bolt NT water pipe
    • chrisman287
