turning up boost past 8 psi?
starfish
450
Feb 20, 2010
Hamilton, New Jersey
I've been driving my car for about 5000 miles now with NO issues(after finally getting my turbo kit set up correctly).Ive been runnin it at about 7-8psi.What would I have to do to run at 15psi?Would the mega-squirt allow me to do this?
The standard MAP sensor that comes with a MS unit is a 2.5 bar so yes the MS can handle it.
Regarding fuel, depends on your injectors, if you have a 1:1 AFPR, fuel pump etc. Bottom line is you need a fuel system that can run at safe pressures and maintain safe air-fuel ratios.
After 8psi most cars won't get enough fuel, you'll need bigger injectors, 255hp fp, afpr, and a way to control them. Megasquirt will take you the furthest but if you are on stock internals I don't know how long your rods will last.
15 psi SAFELY means upgrading your fuel system, internals, and getting a way to manage you A/F ratios. Getting MS would be a huge plus and is the best way to manage your engine IMO.
