turn signal light switch does anyone else have this problem??
streetlegalboi
Aug 7, 2007
tucson, Arizona
the person i bought this car... has many problems... here a list of stuff i already fix... power steering pump.. crankshaft and cam shaft sensors... leaking oil... thermostats.. they didnt even put it in.. rofl... and sun roof... the car right now.. has broken air bags i haven't fix yet.. broken glass.. and most annoying.... is turn signals... i bought a new switch today.. for 80bucks.. still doesnt work.. let me tell you guys what's going on.. when i turn to the right it blinks.. and when i turn to the left.. the damn fuse will blow every time.. i dunno if they messed with the wiring.. not sure.. has anyone else have this problem.. soo i am gonna return the switch ### i thought it was a switch problem.. thanks guys
Streetlegalboi
turn signal light flasher relay... where is it located? i have the manual of haynes... and its a bad picture.. it says right side of steering wheel center? i looked everywhere couldn't find it! maybe i am blind! has anyone changed this before and can give me a picutre of where it is? thanks in advance!
Your flasher button is the red triangle in the center console. It shows it in CAPS on 2gnt but doesnt blow up so not sure exactly, but I would guess its behind the button and console. A fuse only blows from overcurrent which is usually caused by a short as silver bullit said or using a lower rated fuse than what is suppose to be there.
One piece of advice though is that you should try and use proper spelling and grammar. At least sentences with periods and capital letters. You could always just try making right hand turns for now on as well. ROFL
If your emergency flashers work properly then its probably not the relay. The turn signal relay is behind the radio. You will have to pull the radio out to get to it. Once you have the radio completely out it will be a black box with a harness attached to the bottom of it on the right side bolted to the frame that the radio bolts to also. Open your glove box and you will see the head of the bolt holding it in on the right side of the glove box. Then use a ratchet & long extension w/10mm socket to reach it.
