4g63telantra
- 454
- 2
- Dec 10, 2004
Toronto,
I just picked up my Turbonetics wastegate. I see there is too fittings for a hose, (1 on the top and other on the side) just wanted to know what hole/fitting do i use for a MBC?
pj91gsx said:is this why we are haveing problems making boost?
pj91gsx said:so if we hook up one vacuum line from the j pipe to the bottom wastegate line, what kind of boost should it make? I dont know what kind of spring it has in it.
The bottom nipple is used for the Boost controller and the top is for a vaccum line from the intake manifold. If you do not hook it to a vaccum line you may have a boost leak if the spring gives way.
interesting. just to let you know, the previous owner of the car said that all my friend needed was a new wastegate. My friend kept the car in his garage after he relized the car ran horrible. The car stayed there for 2 years. Now I am helping out, we found out it had a blown Xs power turbo and big boost leaks. Now there is a rebuilt garrett t3 on the car. Have the turbonetics wastegates known to go bad?
I am confused on what you just typed. so plug the vacuum nipple on the wastegate that is not used or dont plug it?
pj91gsx said:does it even need a nipple or can I just take the nipple or plug completely out?
