2G Turbo won't build boost
XalD
Aug 21, 2014
Downers Grove, Illinois
I'm gonna start by saying I've been reading forum posts on various websites for days and haven't been able to find the problem.
I have a Hahn Racing 20G turbo and it won't build past maybe 7 psi, and my Greddy boost controller won't effect anything, and there's a ticking noise that sounds like a flutter but my BOV isn't moving until it's supposed to... I'm not sure where to go from here...
Thanks for any help
Can you point me in the direction of how to properly do that? I don't want to just cause more problems for myself.
I would also think the wastgate spring would be and issue. Maybe just check your tubing you might have a leak somewhere.
Brief update, a 30A fuse that I think may be the wastegate controller blows instantly when the car turns on... I'll follow the cord when it's lighter out.[DOUBLEPOST=1408936111][/DOUBLEPOST]What would be the easiest way to check for leaks?
Actually, fix electrical, then report back. What fuse is it?
I'm not sure to be honest, it's unlabeled in an aftermarket fuse box (I'm not sure what else to call it) but it is a 30A that blows instantly, and the boost controller powers on but doesn't seem to control anything at all so I'm thinking it may be a part of it.
I'm thinking I may try to disconnect the thing and see if the fuse blows or not.
Sounds like he has a GReddy electronic boost controller. Probably the Profec B Spec II (a very common one).
Beyond your electrical problem OP, was it acting normal, then did you do XX, and it started acting this way? You could try running just wastegate pressure to see if your noise goes away, but I would really fix that electrical issue 1st thing.[DOUBLEPOST=1408938207][/DOUBLEPOST]LOL I didn't see that he stated the model ^^
It happened after I put in a new stereo, I think it happened during the time of taking off and putting on the battery a few times while running wires.
How would I switch to just wastegate pressure?
I don't mean to ask such presumably obvious questions but I just don't want to cause more issues.
If you bypass the boost controller that's wastegate pressure which I think is 14 PSI (I most def. could be wrong about that).
It's possible you knocked a boost controller wire loose while installing the stereo.
I'll check all the wiring when it's light tomorrow, would that explain the instantly blowing fuse? I guess if it's a positive and it's sitting on a ground point but when I checked it looked like everything to the back of the controller was in and it turns on and all the functions and displays work just it doesn't effect boost pressure.
It could, yeah. Loose wires creating a short, or bare wire touching another.
O.p. sounds like you either wired something wrong or have a loose wire shorting that fuse out. Go over your work! I really hope you soldered all your wires and not just twisted together with electrical tape or butt connectors!!
If it had just a hard time building boost because of too much slack wouldn't I still have some control over boost pressure?
Yeah it's more realistically about 6.8psi, that's why I'm almost certain it's an electronics issue.
So the fuse was too my turbo timer, which I believe is completely dead, but it still doesn't explain my issue.
