turbo waste gate soleniod / crappy idle
spike1on1
Jun 6, 2006
huntingtown, Maryland
When i went to start my car today it was having a hard time. Then when it did start it would barely idle. So i started looking for any messed up vacuum lines and during my search i found that a wire to my waste gate soleniod broke (rotted) off. I checked my vacumm lines and they seem fine. Could this be my culprit. And also does anyone now how to replace the connectors or where i can get one. I bought the car a little while back, and it was running fine for the past couple of weeks.
I'm not sure what wires or connector your talking about, but if its just a regular one, AutoZone has a decent section of connectors and wire. So does radioshack. Homedepot or lowes might have what your looking for. And HarborFrieght over in gaithersburg or baltimore(I used to live out there) sells bulk connectors..
Do you know what the pins are called inside the connector. The wire broke right were it meets the connector for the waste gate soleniod. That what i need, if it was somewhere down the line that wouldn't be a problem. But ive never replaced the pins in a connector before. Hey thanks by the way.
if you need help, PM me. i'm real good with wiring, etc and i have all the tools to do it.
Thanks but i finaly found what i need in the tech section. Thanks for all your help though.
