turbo upgrade w/stock inj's
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I would like to upgrade the turbo on my '93 AWD Talon but still use the stock injectors. Could/should I go with a 16G ported and clipped or jst go with a big 16G? i will also add a Walbro pump. Exhaust is 2.5" Any other advicefor bolt ons appreciated. Mark
You can run stock injectors with any turbo, as long as you don't turn the boost up too high. With the walbro 255 pump you should be able to run about 16 psi with the ported/clipped big 16g. I didn't check your mods, but you'll want at least a full 2.5" (I recommend 3") exhaust, upgraded fuel pump, MBC, boost gauge, some sort of intake, and an aftermarket UIP.
  • Wanted 6 bolt NT water pipe
    • chrisman287
