Turbo Question
^^^^ If this turbo is done you need to do other upgrades to fuel and engine. Theres plenty of other things that would needed to be done. if you go to vfaq.com or there is plenty of threads already on this topic already.
A very simple answer is yes, you can do that. But you'll spend more time and money on a manifold adapter and trying to fix exhaust leaks than you would on a t3/t4 turbo. There are no mitsu manifolds for the 420a that will fit a turbo from a 4g63, but they do make the adapter plates to make it all work.
You're going to need a heck of a lot more than just a turbo though. There's enough info around this site, save starting threads for when you run into some real issues :p
http://www.dsmtuners.com/forums/art...uild-420a-stage-2-turbo-kit-under-1000-a.html
