paul s
- 625
- 6
- Nov 17, 2002
kingston,
ON, Canada
3 cars(2g AWD) 3 different turbos, 50trim, 3052 and GT13 all cars running 22psi, the 3052 and gt13 has 272/272 cams. All other supporting mods included. From a 2nd gear 3000 rpm roll would you expect the "smaller" 50trim(canadianTSI) to pull on the bigger turbos?? I have the GT13 and when we(staytuned 3052) do a 2nd gear roll the cars are pretty much even, should the GT13 car be quicker in the lower gears or would the differnce in size be more apparent in the higher gears as the gt13 flows more air??. All cars are tuned to around 11.4afr on pump> thanks
