Turbo Problem - No Boost, Oil, etc.
Memphetic
115
3
Nov 6, 2005
Punxsutawney, Pennsylvania
Odd thing going on with my turbo... about 12 miles after my engine rebuild, the nut came off the turbine and obviously shredded the comp wheel (and the turbine backed out, dumping tons of oil). I removed the turbo, rebuilt it with a kit I had, and put it back on (all in about five hours after the problem, even!).
However, the turbo will only boost to around 5 psi - very very slowly. Meaning I hit 5 psi around 5k rpm's or so. There is always oil in the intake after a short run, and after it boosts for awhile, it will start producing white smoke. However, the shaft play is (obviously) acceptable, and there are no boost leaks (it'd have to be a pretty significant boost leak, eh?).
It dawned on me tonight that perhaps the SMIC is oil-ridden? It makes sense to me (doesn't have a smoking problem until you start boosting, then it's pretty incessant until you lay off for awhile), but what do you guys think...? Unfortunately I have work to do tomorrow so I may not get to it :[
Dude, I'm in no way shape or form doubting your work, but no one is perfect. If the turbo went bad because of what we already know, then you rebuilt it using parts you had and now you have issues with it. I think we know what the cause is. I would have said maybe the wastegate, but you proceeded to state the oil problem you are having. Therefore I think it just needs to be properly rebuilt.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
