turbo on non turbo transmission
There is a number over to the right of that one.
That is a vin number, go to carfax.com and type it in there.
It will tell you what your transmission came from..
Is this a turbo transmission
im using fidenza flywheel and xtd stage 4 clutch took donw 4 times the trany cose it just dosent work so i whanna know
is it becouse im using the turbo parts on a non turbo tranny
or is is someting else
tanks
Does the verry bottom passenger side say F5M22?
If so it's a non turbo transmission.
plus check your flywheels, does your old one have a hole for a dowell pin?
