Turbo Oil Line Fitting
Galipso
Supporting Member
236
37
Aug 23, 2011
Tampa, Florida
i got the turbo oil cooler line kit but the fitting that goes into the turbo isn't the right size. What size do i need for this application?
Turbo is a cheap 16G, but i used the same bolt and banjo from stock feed from the head, now switching to the feed from the oil cooler.
Green arrow stock bolt
Red arrow fitting that came with kit specified for 16G application
Pretty sure its an M12 banjo. If i had to guess thread pitch, 1.5 but not 100% sure.
You can take your stock fitting to NAPA or whatever and test the thread pitch. But I doubt they'll have the -3an (or -4an) to m12 fitting for you, not sure what your ss line size is there.
i figured it out. Banjo bolt is a M10 x 1.5mm with a -4AN. Found the fitting on eBay
Normal 16Gs have an M12 bolt but i have a knock off so it's different.
