Turbizmo
- 430
- 0
- Jul 3, 2005
Salinas,
California
Hi most of you already know I have a 420a turbo with side mount inter cooler just finished installing. Well my problem is that when I step on the gas in 1st gear I only create 2 psi and when I am on second gear I great 4 psi reving more than 7 thousand and on 3 I lag to the fullest so I dont know whats up. I tighten the actuator rod but nothing. I was thinking it could be that I have a DUAL WASTE GATE actuator both of the outlets I have them hook up on a T and then they run to the turbine I had been told it might be that I just need a BOOST controller but then again I have no clue. Any advice. forgot to mention I have a 2.5 exhaust system.
