turbo bolt up question?
If you are refering to the boltup to the exhaust Manifold and 02 housing, they bolt up the same.
the only other thing when adding this turbo to your 2g. is you need a 2g kit for it, there are several differnces between the 2 turbos. the t25 compressor outlet is low and to the passenger side of the car, you can obviously see this. the evoIII 16g comes out at the top as you can se in the pictures.
research 2g install kit for turbo's to get insight to the requirements.
well, i had extra time so here is good thread on the process.
Thread about 2g installing a 16g turbo for you
T25 is a 2g turbo.
Under No circumstances would a 1g man even look at one in passing..... its a sin.
perhaps you mean a 14b? your stock turbo? or a 13g if your automatic?
if this is the case, it bolts up and everything hooks up the same.
EDIT
i didnt look at your MOD list.
but i wouldnt even consider that evoIII without exhaust and fuel and a few other modifications. of course you can stick it in and run 14psi all day long hitting fuel cut at the top of your gears. if your not modded, and dont plan to buy other stuff in the near future, id just get another stock turbo, and you will be more happy with it. and save
