Turbo Back exhaust necessary?
afunkygbeat
43
Sep 20, 2011
Annandale, Virginia
I just bought a 98 eclipse gsx, and it came with a turbo back exhaust. I want my car built to have around the 300 awhp. But I was wondering if the turbo back exhaust is necessary ( specifically the cats ) because In the state of VA having no cats is illegal, and Ive been pulled over once. Your input would be appreciated !
I'd just get a high flow cat fitted then.
Usually turbo-back or cat-back exhausts reduce the back pressure, which is especially important with a turbo car as less back pressure helps the turbo spin up a bit quicker/better because you have a bigger pressure difference to work with.
I'd hazard a guess that the OP is more worried about Johnny Law having a look under his car and noticing said straight pipe and the absence of a cat :D.
Exactly :thumb:..err. But going back to the original post, would having cats greatly effect my targeted performance?
100% sure you could make the power with a full oem exhaust, it would be counter productive but it is possible. You could always get a cat or axle back system or a high flow cat. Some people keep the full oem with an electronic cut out
Depends if they tabbies or not :).
OK, stupid feline jokes aside, I would say you can get that sort of power with a cat - after all, there are plenty of examples out there that do. I would probably get a high flow cat instead of an OEM-spec one simply because they pose less of an obstruction in the exhaust and thus contribute less to the exhaust's back pressure.
thanks for all the inputs, inlcuding the cat jokes -.- made me crack up a little. But thanks for all the advice, I guess im going to remove the straight pipe and put some cats on
make sure you read up on your states emissions law, just because you have a cat doesnt mean you will pass. some states require CARB exempt or full OEM emission controls. if that is the case, find an OEM cat, or a CARB exempt, and then you are looking at a few bucks, but remember, Emissions are just for johnny law, if you live in a highly populated area, you will be smelling your exhaust and everyone elses for a long time coming
thanks for the advice, I forgot about that. I will be looking into that this weekend when I get the car checked out.
I have a 3" muffler that looks like and is the same dimensions as the factory one and I don't get messed with. Its a Summit with a offset inlet and center outlet. It only cost about 30 bucks if I remember. Cops always go after any of the bazooka looking muffler cars.
Cheapest solution would be to find a large enough cat on a junkyard, get the heat shields from it, and tack weld them to the exhaust pipe. Will fool a visual inspection, but a poorly running car will not fool a sniffer.
the straighter the pipe = less restriction = less back pressure = more power.
running no-cats where i live is illegal also. pigs don't check under your car he, noise complaints could land you some fines tho. only hassle is replacing your stock exhaust system every 1-2years to pass aircare.
yeah, its too much of a hassle for me. Decided to put cats on so I can pass emissions and put on a less flashy muffler
