tried shiftin into 2nd at 5.5k rpms
GabedsmT
Nov 27, 2007
Allentown, Pennsylvania
hello. sorry for postin this here but for some reason it wouldnt let me post on tranny, plus i have some other questions.. i have more than a couple questions hopefully ppl with more experience could help me..
1.- today i was driving my car back from school... and for some reason i need to take off quick so i step on the gas on 1st gear, and i tried shiftin into 2nd at 5.5k rpms.. and it wouldnt let me... so i waited as soon as my rpms when like at 3.2k it would let me put it on 2nd... it only happens on 2nd i have noticed... and only when im higher than 3.5k rpms... throw out bearin? tranny? clutch?.. i been hearing the throw out bearing grinding when cold.
2.i have accel 30lb(310cc) and a super fmu and im wondering what should be an aprox. of my fuel pressure with those injectors.. and what disk should be fine? 7:1, 5:1, 3.25:1 and 2.5:1...
3.- over the spring i wanna do my a cometic bore 88.5mm headgasket and arp headstuds.... how much boost with the fuel set up mention before i would be safe to run.. this is my everyday car..
thanks for anyone tha desires to help... thanks
Sounds like a synchro is going bad...
That depends on a lot of different factors, but I wouldn't count on more than 16psi.
VelocitàPaola;151428798 said:
Sounds like a synchro is going bad....
i never had experience with those, how do i fix that?
on stock pistons and rods?
~8psi is a limitation of the common "255lph + 235cc + 12:1 FMU" combo, not the rods or pistons. (I'm considering recording that to a macro.)
It is unlikely the stock internals would handle 16psi.
how can i fixed that only by rebuilding my tranny??? n if so does anybody has a tranny for sale? hahaahaa.....
