Transmission Troubles
96EclipseGS-T
Nov 6, 2006
Jackson, Missouri
OK got a question for you guys...when i bought my car i had to rev the engine up alil bit to shift into 3rd gear or it would grind really bad...sometimes i could get it into gear w/o reving...SOMETIMES. Now it wont go into third AT ALL, no matter what i do. 1st, 2nd, 4th, and 5th shift flawlessly but it wont go into 3rd at all. anyone know what could be wrong?
Synchros sound worn out.
I wonder if the linkage might be out of a adjustment? Although I think that usually affects at least 2 gears, it might be worth looking into that.
At least you could get by revving 2nd a little higher or luggin 4th a bit.
When was the clutch last replaced?
Synchro's worn out. Drain your fluid and see what it looks like. Should have some brass shavings or sparkly.
