tranny q's
snapp
Mar 17, 2006
Edmonton,
Hey guys I just purchased a Eagle talon 95 tsi awd every thing looks good except I have one problem .I turn the car and then I put it in gear 1 and try to go but it wont move and then I also try putting it in gear 2 and it still wont go and then I also tried reverse and still there is no movement. It feels like it cant feel the gears changing or it jus cant feel the gear at all.
if you let the clutch out and nothing happens then try this. Turn the car off and put it in gear and try to start it if it starts to jump forward when your starting then its because your clutch isnt dissengauging if nothing still happens check your shift cable lines that run from the shifter to the tranny and make sure they are connected
