1G Tow point?
tsi617
79
7
Mar 10, 2016
Richlands, North Carolina
Where can I hook up a trailer winch on my Talon. The rear of the car is poking out of the side of my house and I'd rather not push it (not running at the moment) out from the dirt path on the side of the house.
Preferred is the rear but where is the front factory points? Not looking for a JDM gigantic d ring.
I've done it two ways:
1. On the subframe there are 2 hole in the front subframe arms. If you have a tow rope with small enough hooks, you can hook in there. (pic 1)
2. Or hook on to the front seam lip on the subframe near the middle. (pic 2)
Either case, I'd recommend a tow rope so you dont shock load it and bend something. Just take your time.
Thanks. I usually use a tree saver with a tow strap for moving things. The tree saver is great for preventing damage.
