Torque
sedah
59
Mar 26, 2004
vancouver, Washington
I did a short search ma tools are outside its an appartment oy
I need the torque specks for the front supspension knuckles i believe its called
girlfriend took off with ma books cause i sat a moment in her car with em and forgot
oy
if anyones got a chiltons or haynes this shouldnt be real hard
speaking of which
how bout all the torque settings for the front 1g awd Thanks
Strut
Upper mounting nuts 29 to 36
Damper rod-to-insulator nut 43 to 51
Strut-to-steering knuckle bolts/nuts 80 to 101
Stabilizer bar
Bracket bolts 22 to 30
Link nuts(ball joint type links) 25 to 33
Balljoint to Steering knufckle nut 43 to 52
Control Arm
U-bracket-to-body bolts/nuts
Long bolt 72 to 87
Short bolt 58 to 72
Nuts(hehehe) 25 to 34
Pivot bolt nuts 72 to 87
Sedah, if you really need torque specs again, just visit autozone.com's repair guide. They give you all the specs there and more than the Haynes manual does. Also, they're on pictures ;).
Thanks.
i didnt know about autozones repair section
that helps alot
i appreciate the help!
