Timing spike during shifts
dls93tsi
441
Nov 21, 2003
Schuylkill Haven, Pennsylvania
I fixed a few problems on my car last night and took it out for a log run. The car ran great, except when i pushed the clutch in to shift the rpms would not drop they would linger for a second and by that time i had it in gear. my friend was holdin the laptop so i wasnt watchin it, but when we got back to my house and i looked at it, heres a quick overveiw of what it said(not all entrys are in, just the relevant ones)
Also i seem to be a bit lean, am i correct on that?
~RPM, %adv., knock, O2
4500, 25, 0, .78 1st gear the whole gear looked basically like that
5400, 45,0,.58 (shift)
4600, 25,12,.79 2nd the whole gear was knocking like a sombitch
5600,45,0,.57 (shift)
4500,25,0,.80 3rd looked like that through the whole gear
5300,44,0,.57 (shift)
any suggestions on why the timing is spiking like that?
The timing spike is normal. When you shift, you let off the throttle, which decreases airflow to the point that the ECU is no longer in open-loop (WOT) mode. It will go back to reading the O2 sensor and aiming for the magic 14.7 a/f ratio, as well as maximizing timing for complete fuel burn. When you get back on the throttle full, it will go back to WOT, pull timing down, and run a safe, rich a/f ratio.
As for you running lean, it kinda looks that way, but I'm sure we'd all like to see the complete log to determine that. If 0.80 is the highest that your O2 value gets, then yes that's probably a little lean. The timing seems pretty high, too, but then again I have a 2G so I'm used to seeing timing in single digits and going no higher than 40 degrees.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
