dropped99gs
- 139
- 0
- Mar 10, 2011
dallas,
Texas
So far I am considering myself extremely lucky. I was returning back to the Dallas Tx area from a trip visiting family. My g/f and I are cruising along and out of nowhere my car misses. My initial inclination is something with ignition/spark, or fuel delivery. I immediately exit and the car dies as I pull into the service station. I get out, pull my tools and everything, pop the hood. No fluids anywhere, no smoke or anything along those lines. So i pull the wired and take a couple of plugs out. It was overcast and raining so it was hard to judge, but initially i thought it was a spark plug or ignition coil problem. The plugs looked iffy and due to the hour it was not possible to get replacement. Thank goodness we have AAA and a 100 mile tow. It was 70 miles from where i was to home. The next day it would not stop raining, therefore I was forced to wait and make a determination. Yesterday the weather cleared and I was able to get under the hood. I checked for spark from the ignition coil and it was nonexistent. So I replaced the coil and plugs, turn her over and it was a no go. Scratched my head for a while, stood back, checked for spark again with new coil and nothing. Now the worry starts setting in. I have my g/f turn it over a few more times and i hear something around timing belt area. I pull the inspection cover and have her turn it over. Sure enough timing belt had worn down to wear it was just barely slipping. I live at an apartment complex and all of my family where i have access to shops and tools needed are about 2 hours away. So my only option was to tow to where I get work I cannot perform myself done. It was $50 flat rate in town tow, and the shop charged $92 for compression and leak down tests to ensure no valves were bent etc. That was were I received the first piece of good news, no bent valves and everything checked out with even compression across the board.
So far everything seems fair. Then I was given the estimate for the timing belt replacement.
Without parts, but including tow and labor performed and the labor costs for replacement work the bill is at $694. So minus the tow and comp/leak tests its around $550.
I was told that they are going to have to decharge and recharge my a/c. I know that service alone costs close to $200. From the forums and other research I have not seen anything involving the a/c.
I've located the parts myself and after calling around and internet research heres what I'm paying for parts.
$90 for hydraulic tensioner
$105 for timing belt kit w/ idle and adjustment pulleys
Initially the shop was going to charge me $189 for timing belt kit alone.
I'm picking the parts up tomorrow at CarQuest - they earned a new loyal customer with their price matching - they didn't just match the price either, they beat it.
I like this shop, its owner operated and all the work I've had performed there thus far has been A+. They have never tried to up-sale another repair and their hourly rate is competitive.
These guys know what they are doing and were chuckling about all the timing belts they've done when this engine was fresh on the market.
The only thing about the repair costs I'm having trouble understanding is the a/c work. Is that necessary to perform this job or not?
I would like to see that $550 in labor become more like $300.
My goal when all is said and done is be as close to $600 as I can.
I'm already at $350 with timing kit, tensioner, the tow and tests.
Am I being unreasonable and hoping for too much or should I be able to get the labor bill down to $300?
1999 GS Anniversary edition -
but I was optimistic it was something minor I could do at the apartments.
. But after this is over and done with I firmly believe my car will be 100%.
