Timing Belt replacement in N.E.Pa.??
Looking to get my belt replaced in the next couple days.....anyone have shop suggestions? I'm near the scranton/wilkes-barre area.
Do it yourself and save yourself a bunch of money. It's really not hard to do. :thumb:
These two links will tell you virtually everything you need to know:
http://www.geocities.com/eclipsed4evr98/Timingbeltprocedure.html
http://www.2gnt.com/www/corbin/rebuild.html
You'll want to replace your pulleys and probably your water pump while your at it. You may also want to replace the tensioner. You can easily spend a couple hundred in parts alone so it might be worth doing/learning on your own. I was deathly afraid of doing my own timing belt for fear of ####ing up the timing, but once I did it, I realized it's rather easy, albeit a bit time consuming your first time.
^i hear ya on the work thing, i get some crazy hours. And I don't know why I thought you had a 2gnt when your info says you have an awd 1g, guess my links are useless
  • For sale 2g Eclipse/Talon AWD Partouts
    95-99 2G Eclipse/Talon AWD Partouts
    • Sdcryan1
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • Wanted 1g 6bolt Balance Shaft
    Does anyone have a rear balance shaft for a 1G 6bolt hanging around? For some reason, this one...
    • Gabe92RTTT
