thumping noise after uicp install?
98x
Mar 16, 2004
Chicago, Illinois
After I've installed my uicp with the hks bov. I've noticed a thumping noise in the intercooler area. The noise comes and goes, sometimes it gets louder and then goes away. Is this something I should worry about. I've checked all the connections and clamps over three times to make sure there are no leaks. Any idea what it might be????
make sure that you put your fender wells back on securly, when i did my uicp i pout it on loose cause i lost some bolts and it rubbed on the tire at about 60-70 and was smacking arround
i'm pretty sure that nothing is hitting the fender or rubbing against it. It sounds as if the noise was coming out of the intercooler or the piping. It sounds like when you pour out a bottle of water, and when you get to the bottom, you can hear that hollow noise, thum thum thum thum.
