Thrust Washer help
9920gGST
Aug 27, 2006
Hayden, Alabama
Ive looked around and cant really find anything helpful on this.
I have a 99 GST Eclipse and am rebuilding the engine and need to know where the thrust washers go.
Also, on the main girdle, there are 2 bolts that look different than the rest of them, what location do they go in?
thanks in advance
thanks in advance
For the first question, I dont know.. Manual might tell you
As for the second one, the 2 bolts are the smaller ones, those go on one of the ends, I dont recall which side, you will only be able to bolt them into that area.
thanks in advance
They go on each side of the center main bearing in the block.:thumb:
Joe
  • Wanted 6 bolt NT water pipe
    • chrisman287
