throttle body
You will have to make an adapter or a custom upper intercooler pipe because the n/t tb has a flange casted into that the intake hose slips over. The turbo tb is machined flat with an elbow that bolts to it. Other than that, I have read many times they are the same size on 1gs.
Edit: forgot to mention that the n/t tb is also one vacuum port short.
i may be wrong about the specific sizes but i believe the non-turbo throtle body is actually larger. i will do some checking and get back to you, i am running a 92+ non-turbo on my 99 w/6 bolt swap
The 1g N/T 2.0 uses the SAME SIZE throttle plate as the 1g Turbo throttle body.
It has a wider inlet, but it TAPERS down.
So, in effect, they are the same size.
I should know, I've rebuilt plenty of each for people.
Hal
isnt this kinda better in a way adding more air into it because of the taper.
  • Wanted 6 bolt NT water pipe
    • chrisman287
