2G Thinking of buying 96 Eclipse GST
DakMac
Sep 1, 2009
Normal, Illinois
ok, so i came across a 1996 GS-T this guy was selling it for 1500 so i offered him a trade of my four wheeler (which was a piece) for his car and he took it so im pretty excited... the only thing is that it has a couple of problems i haven't encountered with my previous dsm... he said it needs new cam bearings, a cam gear key on the crank, and a distribution block gasket. and i am now just informed that the reason i have never heard of these parts is that they dont exist... makes sense LOL well im off to see what the real problem is i guess...
ok so here is the latest... i just received an email from the guy i bought the car from and this is what it says word for word "the block that has 2 hoses come off it that go to the turbo had the gasket go out and the oil sprayed out and didnt oil the cams. that fried the cam bearings. when the cams stopped turning the belt couldnt turn to the timing gear on the crank and stopped without the crank stopping and the key in it was twisted out... so if that makes sense to anyone i would appreciate your help
Just to let you know the guy you bought it from must have been mentaly challenged.......None of those parts exist. You need to edit this thread and fill us in on the real problems before you get made fun of.
Did he also tell you the muffler bearings needed replacing or the blinker fluid was low? Lol. Do a compression test, leakdown test, check the end play in the crank, check turbo shaft play...
LOL.... But yes do a compression and leakdown test
