The 97 GS-T project begins
proteusx301
185
4
Apr 1, 2009
Cary, North Carolina
I'm new to the forum, however I've been lurking around for about 4 months now, ever since i bought my car. I'm in no way new to working on cars, however this will be my first high performance engine rebuild. I've done many engine rebuilds for work, however they all used factory parts and by the book procedures, so they were mostly cake. I just basically wanted to get on here and lay my plans out on the floor and have some other people look at them, perhaps throw in some of their own ideas or recommendations. Any helpful information is always welcome.
The basic plan is that I'm shooting for between 350whp to 400whp for a daily driver. Engine management will be a EPROM 95 ECU with DSMLINK. I'm not the kind of person to do a job halfway, so someone tell me if im cutting corners somewhere.
ENGINE- donor motor is a 95-96 7-bolt
Block will be sripped bare and hot tanked
cylinders will be overhoned ten thousandths
deck machined flat
stock pistons and rods reused, havent decided on what kind of piston rings yet
clevite 77 rod and main bearings
ARP hardware kits will be used when applicable
balance shafts will be removed
cometic head gasket
ARP headstud kit
head will be hot tanked and cleaned
mating surface machined flat
3-angle valve job, using stock intake valves, and evo exhaust valves
port job
hks cams (havent decided on 264/272 or 272/272 yet)
all of this of course topped off with complete rebuild gasket sets
all new timing belt components
Evo III exhaust manifold
Evo III turbocharger
Evo III O2 housing
RRE 3 inch downpipe mated to a 3inch high flow cat, 3 inch cutout added to DP
Apexi N1 catback
225 lph fuel pump with rewire
STM tank-to rail fuel kit
STM return kit with FPR
All this will of course be supported by the appropriate engine management and monitoring gauges. I will be re-using my existing transmission, havent decided on a flywheel and clutch kit yet. Well thats basically it for now. Thanks in advance for any advice that is given.
