Tdo4hl?
IllEagle2gTSI
Nov 22, 2004
ellington, Connecticut
about a month after i got my 2g tsi i dumped all my engine oil into the intercooler :barf: .Snapped the shaft right in half and shot about a quart all throughout my intake. Well i found a replacement and i bought it, come to find out it wasn't even a t25. On the compressor housing it reads TD04hl and looks very similar to the 16g. It bolts to the stock 2g manifold and o2 housing but my oil feed,water feed and drain lines don't fit. Also the wastegate actuator wasn't on the turbo(t25 doesn't fit). Does anyone have any remedies for these problems? anything?.....thanks for the input
Do you speak English at all?
Thread moved to Problem Diagnosis forum.
On Topic:
Let me try to clear some things up since your post is very hard to read.
Are you saying you snapped your turbo shaft in half and caused pressurized oil to invade your intake track and pool in your intercooler? Then you found a replacement turbo and bought it before you even made sure it was the correct replacement? Now you are stuck because nothing seems to fit right besides bolting to the 2G O2 housing and manifold?
