TDC sensor
sphinx0nine
99
Nov 13, 2003
Calgary,
OK. ive trying to get my car to idle .. no luck yet.
using the TMO software.. i see that theres a sensor that goes from high to low and makes the car go up and down on the idle..
it shows that its the TDC Sensor..
i dont know what it is...
any help with this is??
I believe you just have to get a new cas. On a 1g its this round thing beside the valve cover on the rear passenger side. You can either get a green top or black top cas, either will work but the black top cas is a hall-effect sensor that has higher resolution. Look around at a junk yard or on the classifieds.
