Talon TSI
If this is correct you either have parts on the car that you are not aware of or the car also runs like crap as you cannot just install larger injectors and that's it. The car will not run correctly if at all. See if you can find out what all is on the car. If somebody went to the trouble of wiesco pistons then there are likely other things. Got any engine bay pics?
If this is correct you either have parts on the car that you are not aware of or the car also runs like crap as you cannot just install larger injectors and that's it. The car will not run correctly if at all. See if you can find out what all is on the car. If somebody went to the trouble of wisecracking pistons then there are likely other things. Got any engine bay pics?
I don’t as of now the car is out of town but when I go back I will get some pictures and look through it
