Talon ESI Questions
blackmirage
119
Jun 23, 2006
Clarksville, Tennessee
Hey guys, I'm trying to make sure of something. The Talon ESI ONLY came with a 420A correct? Never did it come with a 4G63T, correct? How hard would it be to swap it from that to a 4G63T, and do a Manual Trans swap? Does the engine just drop right in, or is it fabrication that is needed to do it? I am thinking that the trans swap to manual wouldnt be as much as when I researched it for the AWD, but please correct me If I am wrong. Thanks for the help guys.
ESi's only came with the 420A and the ESi's were only 95-98 models. It is very hard to swap the 4g63 in since it is situated 180 degrees around so all new motor mounts, new ecu, new wiring harness and many more things would need to be fabbed up. It is in no way worth it to swap motors and if you try it, you will probably never finish it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
