Taking the next steps!!
dherron
87
4
Jun 12, 2004
Uhrichsville, Ohio
Ok You can read my current list of mods. So what do you think should be my next set of mods? I know that I need injectors and and BIG ASS turbo but other then that I need to know what I am goin to need to tune this bad boy and what will really give me big power gains? And also i just welded the diff in one of my trannies, do you think i should install this on the street or just stick to the open diff. with a slowboy lsd block? Thanks a million
it all depends on what you want to do with your car. for you to get some pretty decent power gains you dont need a BIG ASS turbo. The 14b that comes stock is plenty capable of pushing 16lbs at least. If you want to upgrade to a different turbo for better airflow and not really for more boost than your offered to do that as well.
The exhaust system on a DSM is pretty restrictive and the tech guide in this forum does a great job of highlighting what you need to be doing.
As far as tuning you can do a couple of different things as far as getting the most out of your fuel/air/motor.
A SAFC can be used to adjust fuel and air ratios for power dispursment.
A fine-tuned system is what is called DSMlink...which is a biggyback system that lets you take control of the injectors, RPM bands, clutch control...all of the bells and whistles. you need a program and a logger to run DSMlink and you can research those topics in the forums. best of luck to you. :thumb:
