take 45 minute drives and the car doesnt like to shift
dnhieu
1,927
17
Aug 16, 2004
panama city, Florida
well everyday i drive about 45 mins to school and another 45 mins back and when its really hott outside (90 degrees +++) it gets really hard to shift into any gear. now when i first drive to school at like 8 in the morning while its still kinda cool it shifts fine, but when its hott outside (around 12) it doesnt like to shift. i was just wondering if anyone else was having this problem? if not what kind of high temp fluids are you guys running?
thanks
Pretty sure the tranny runs 90 weight gear oil, but what you are describing is weird usually its had to shift cold and easier hot. Is the fluid at the proper level?
Its full to the top. in fact i squeeze as much of the stuff in as i can. im thinking of trying some high temp gear oil. i had bg in it untill i had to pull the cv axles to drop the oil pan. i would like to try some red line oil. has anyone tried it in dsm trannies?
thanks
It would be hard to shift if it was overfilled. Did you fill it till it was about even with the fill hole that is the proper level anything more than that and its overfilled.
make sure your shift linkage is nice and tight on the tranny bracket. mine did the same, boggled my mind till someone looked under the hood and seen it flopping everywhere ROFL
I was talking to Mr. Sheppard about a week ago, about getting a tranny built, and he suggested to run 2 quarts of MTL Shockproof, the rest with pennzoil scyncromesh. I would like to think that he gives good advice.
Yeah I would think that Mr. Sheppards advice would trump all of ours on the subject of DSM trannys. But yeah you should check the linkage as well.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
