Taillight tinting
Twistedhellion2
Jun 7, 2011
Mechanicsburg, Pennsylvania
Was wondering if there is something I can buy to keep a good shiny look while tinting? I saw a vinyl type film on Ebay and it sparked my interest as I've wanted to tint my tails for a while
I've done nightshades before and had it look incredible. The key is to wetsand before the clear. Also use high quality autmotive clear.
Bingo ;) Plus I have a set of stockers if anything happens with the cops. No point in tinting a set just to remove it later, do it once, do it right.
Do not use nightshades, I have not seen one person do it and look good yet.
Lamin-x.com best stuff, period.
See below.
^This.
Proper prep is key, when I get home later today I'll post a link that's got lots of good info in it.
I use a smoked vinyl film on customer's taillights. I have used Lamin-X and found that the film is quite thick and on cars with a lot of curve, the film will just pull back.
I now use RVinyl and works quite well. I sometimes use steam to get it to conform to really curvy tails.
I just prefer a vinyl application, instead of spraypainting a set of lights. The vinyl can be removed right there on the spot if you get pulled over for it...
Am I missing something, they only make the film for newer eclipses..Or do you just buy a sheet and cut to fit??
I used the lens tint from autozone. Did it on 2 different vehicles. Spent hours wet sanding and doing everything right. And just sprayed the other one while it was on the car. No sanding. Just wiped it down with a rag to get dust off. They look 99% the same
Decisions decisions! I do like the film idea I tried spraying my old sidemarkers and my friend's tails and both came out sub-par...but were prepped poorly
In order for niteshade to look good, wetsand with 800 first (the surface needs to be textured or else it doesnt stick as well), do a coat of niteshade, wetsand with 1500, do another coat, wetsand even mooorreee, then clear, and buff. They will shine like crazy ;)
I have never sanded my tailights on a car before I tint them incase I have to take it off.you can just let it soak in gasoline or fingernail polish remover for a few and wipe it off , I do agree that film tint looks better to though.
Niteshade is the cheapest and easiest way for a great smoke... Like others have said. Wetsanding makes it look great. I have no clear on my 3 coats and its still really shiny.
