EclpzLvr97
- 1,413
- 2
- Oct 3, 2002
Howard county,
Maryland
Okay, so I did a search and found no one with a similar story to mine.
Basically my driver side tail-light has an electrical problem of some sort. I replaced the sockets because the 2 metal pieces inside the socket that make the connection to the bulb had melted down a bit. Therefore it didn't make good connection and my turn signals would hyper flash.
So I replaced the sockets...rewired new ones in from a parted out 2G. All worked great for several months until last night. Seems like the same problem. The bulb is not burnted out. Both filiments are there. Sometimes it works, sometimes it hyper flashes.
I'm afraid the socket pieces are melting down again. It was dark when I tried to check last night, but it seems like the 2 "nipples" on the bulb itself were a slightly melted.
I don't understand why this happens as I am no electrician. Is there somehow too much power/voltage going to it or something?
Also, I've noticed there are 2 different bulbs that "work" (notice I put it in quotes) for these tail lights. There is the bulb number given on this site somewhere, and then the manuals in the auto store give another number. Both will work, so I don't know that that is the problem...not to mention the bulbs look exactly the same from what I remember. Is there maybe a watts difference between the bulbs?
I really hope someone has some insight for me. It's quite an annoying problem. Maybe I should just have the whole damn car re-wired since some interior lights don't want to work sometimes either (seperate problem).
