Synchro theory + double vs single
MNGSX
2,533
25
Mar 30, 2003
Bloomington, Minnesota
Everybody asks about single v double synchos.. This is 3s stealth stuff while the transmissions are different they operate the same way.
http://www.stealth316.com/2-awd4.htm
Also go back one page.
Why the F did'nt :dsm: put a planetary gear center diff in a DSM like the 3kgt-Vr's.. :rolleyes: so much stronger..
It would take alot of work.
Hog out a CD housing... Mount a sun gear inside... ETC.. Possible.
Also I would use wider and perhaps more gears than the 3s diff.
3s has 3+3. Three outer which drive three inner... I'd do atleast 4 pairs..
The closest thing is a quaife but the helical gear on the outside of the case is problematic...
Sending a customer back the same housing assures the helical gears like each other.
