Synchro Rings
Hey
Does any one know where i can get 2nd gear Synchro ring for my 98 eclipse gst????? need it before i drop my new turbo in!
Go to the dealer .... you need to take most of the trans apart to replace this so there is most likely lots more you will need. You need to take the trans apart and determine all the parts you need first ... then order it.
You don't just buy a synchro and toss it in the trans like some bolt on part, you have to completely tear it down to get at it. You WILL destroy bearings and seals getting the assembly apart. You'll have to buy a rebuild kit minimum (bearings and synchros). And if it was grinding expect to replace more parts.
It sounds like this is way over your head, start looking around for trans shops.
